Hi I wish to have panning info sent to my listener on the 3rd person camera and attenuation data being calculated based on the characters position. Is there a simple solution to this? I must stress that my C# implementation skills are quite basic so enhanced details would be appreciated.
Cheers
              You will have to drive the listeners values manually to do this, instead of using a FMOD Studio Listener component.
- You will need to make your own script that calls Studio::System::setListenerAttributes.
- This function takes an FMOD.ATTRIBUTES_3Dwhich is the same as FMOD_3D_ATTRIBUTES.
FMOD_3D_ATTRIBUTEShas members for: position, velocity, forward and up. You can then drive those how ever you wish.
For example:
  GameObject player, camera;
  FMOD.ATTRIBUTES_3D attributes = new FMOD.ATTRIBUTES_3D();
  void Update()
    attributes.position = FMODUnity.RuntimeUtils.ToFMODVector(player.transform.position);
    attributes.forward = FMODUnity.RuntimeUtils.ToFMODVector(camera.transform.forward);
    attributes.up = FMODUnity.RuntimeUtils.ToFMODVector(camera.transform.up);
    FMODUnity.RuntimeManager.StudioSystem.setListenerAttributes(0, attributes);
