I didn’t see anything when searching about this and hopefully I’m just missing something simple.
I have my banks setup in ‘Assets/StreamingAssets/FMOD/[platform]’
I have a timeline marker callback for everytime a music track loops to do something in Unity. This works great in editor, but when I make a build and test on device (in this case a Quest 3) the timeline markers don’t fire.
One thing I’ve noticed is that when I build, unity copies all my banks to ‘Assets/StreamingAssets/[platform[’ even though my settings show what I noted above. Could this be the cause?
All my audio plays in the build, it’s just that I don’t seem to get any callbacks. Very strange.
Any help is appreciated! Loving the power I will soon have using FMod.
Ok, I was able to figure this out finally! The handler for the callback was not a static method. REMINDER for everyone using callbacks. They must be static to run on their own thread when compiled out to IL2CPP. I finally found the error buried in the adb logcat. :-/
Thank you for sharing the information.
Could I please grab a bit more detail to help troubleshoot? Specifically:
- The version number of the FMOD Unity integration you’re using
- A code snippet showing how you’ve set up the timeline marker callback
It could be, the banks files should reside in the Assets/StreamingAssets directory.
During the build process, Unity automatically copies these banks into the appropriate platform-specific subfolder. If your banks are located in Assets/StreamingAssets/FMOD/[platform], Unity might not recognize them correctly during the build, leading to issues like missing callbacks.
We recommend to place your banks directly in Assets/StreamingAssets and let Unity handle the platform-specific organization.
Also, have you had a chance to look at this Timeline callback scripting example? It might help verify the setup.
Thank you for sharing the solution!
