Control SeekSpeed with Code
Hi, i try to make a dynamic music in my demo, and i use all the time the same music in loop, but i change the volumen of the instruments, in different areas of the scene.
I use the seekspeed to make the transitions between zones, and make the fade in and out of the tracks smoother.
The thing is, that i would like to control, the async of the SeekSpeed, to change the speed from n/s to instant, in some cases, for Ascending or Descending.
Someone knows how is the code line to make it?
thanks
Hi David
It is not possible to change the seek behaviour of parameters outside of the Studio UI.
Cheers
Derek
