I have a Linux player that is getting error (51) “Error initializing output device.” He says audio is working on his machine and he’s tried speakers, headphones, etc, all with the same error. Audio works fine for most of my Linux players.
Is there a way to turn on better error messages without using the logging FMOD?
The logging version of FMOD is the main way to get more information about what’s going wrong. As for things to try, FMOD will make a choice between using PulseAudio or ALSA as the audio interface based on the response from pulseaudio --check. If PulseAudio is available it will use it otherwise it will fallback to using ALSA.
You can influence this choice (as a user) if PulseAudio is misbehaving. Use of the environment variable FMOD_ALSA_DEVICE allows you to specify an ALSA device to use instead of the default. Setting FMOD_ALSA_DEVICE = default should force the game to use the ALSA default device or any valid ALSA device name if that’s your preference.
