I am still fighting with integration
I have 2 scenes in Unity: “a” and “b”. There is different music in each scene. I would like to fade out music “a” while i jump to scene “b”
There are trigger colliders that are changing my scenes. I am trying with parameters but i dont know if thats good idea.
Any clues how to make it work?
thx
Edit:
This video shows that in one scene trigger zones works fine but when i change scenes i dont know what to do
To use a parameter change between scenes you would need to keep the object with the event attached around, using DontDestroyOnUnload. Otherwise when you unload a scene, all the objects in that scene get destroyed, including any references to events you had.
Also when you reload scene a another instance of the event gets created, you can use the “Trigger once” on the Studio Event Emitter script to make sure it doesn’t get re-triggered, or destroy it before creating another instance.
