Pause Seek Speed when using setPaused()
I’m currently working on a game where inside of our Pause Manager scripts, I’m using the following to pause the SFX events when the game pauses:
if (Paused)
     FMODUnity.RuntimeManager.GetBus("bus:/SFX").setPaused(true);
else
     FMODUnity.RuntimeManager.GetBus("bus:/SFX").setPaused(false);
The events are pausing and un-pausing as designed! However, some of the events in the SFX group may be paused while global parameter seek speeds are affecting them. It seems as though when the event pauses, the seek speed does not.
Is there anyway to pause the seek speed (global or local parameters)?
Local parameters will be paused when the event is paused, even when paused via the Bus. However, since global parameters are updated at a System level it is not possible to pause their seek speeds.
Thanks Richard! That’s what I needed to know!
