SOLVED: EventNotFoundException: [FMOD] Event not found] and ObjectLookup::get : Lookup failed for EventModel
EDIT: Solved by manually deleting the fmod unity plugin from assets->plugins->fmod, then reimporting fresh
EventNotFoundException: [FMOD] Event not found: {026abc07-54ad-4a88-9c93-20d37d229bcf} (event:/SFX/Cars/Engine/EngineTotal)
FMODUnity.RuntimeManager.GetEventDescription (FMODUnity.EventReference eventReference) (at Assets/Plugins/FMOD/src/RuntimeManager.cs:1198)
Also getting:
[FMOD] ObjectLookup::get : Lookup failed for EventModel
All the folders are set to default in FMOD, and Unity is looking in the Desktop folder.
We are building assets and metadata to seperate banks.
I deleted all the built banks then rebuilt, but that didn’t fix it.
I’m wondering if possibly the issues started when I recently moved to 2.02.08, while unity was using was 2.02.07. I uninstalled 08, and went back to 07, but this issue is still happening. Is there possibly some residual 08 stuff affecting this?
Really hoping someone can help me with this
Thanks. This worked. Same version same problem.
I haven’t been able to reproduce this problem. What version of Unity are you using?
hey jeff sorry for the 2-year late reply. I never saw it until now.
I actually don’t remember the version I was using, but currently we are on 2022.3.18.f1, and our last version was very close
